BLDC Motor
BLDC Motor
What can be the side effect of placing a thin Aluminium tube (1mm) between the stator and the armature?
RE: BLDC Motor
1 You will get extra losses due to eddy currents in the Al. Can be quite significant.
2 You will reduce capacitive coupling from stator winding to rotor and yhus reduce bearing EDM. You have to make the Al conact the stator iron for that.
3 Less mechanical tolerance left for rotor excentricity and bending.
4 Internal circulation may be hindered.
Gunnar Englund
www.gke.org
RE: BLDC Motor
RE: BLDC Motor
RE: BLDC Motor
What are you trying to accomplish?
RE: BLDC Motor
RE: BLDC Motor
RE: BLDC Motor
Plastic will work most probably more as coating or casting in production, more difficult to achieve these thickneses for prototpe.
Thanks for your advice
RE: BLDC Motor
If you need to put metal in between I would recommend to use stainless steel, non magnetic and quite low conductivity.
