Blanchard Cortland Bonus Grind head
Hi All,
We recently aquired a 36", 50 H.P. Blanchard grinder, and it came with a standard head and a bonus grind head, both made for segments. I believe (but not positive) that the segments for the bonus grind head are thicker, thus covering more surface area, which in turn grinds material a bit faster. But, the bonus grind segments also fit on the standard head so it begs the question, what is different about the bonus grind head that requires it's use when using bonus grind segments? Does it have to do with the placement of the coolant holes for the coolant coming through the center of the head?
Thanks for any help.
Ranck
Ranck
RE: Blanchard Cortland Bonus Grind head
