How about multiple expansion for internal combustion?
I wonder is the multiple expansion that is used in steam engine to improve efficiency can be apply to internal combustion engine.
I thought that the first cylinder will work exactly in the same way as it work in Otto or Diesel, the exhaust will go to second cylinder to do second expansion. The second stage could look very match as it do in steam engine with double piston stroke. I assume that the temperature in exhaust gases are low to be handle with that approach. The whole system could have (as in advance steam engine) 2,3 or 4 stages of expansion. As in steam engine the pressure after last expansion should be pretty low (probably no muffler will be needed).
I wonder what a theoretical limits of that approach? Could this work at all? Does single 4 stage expansion will work like 4 cylinder 4 struck IC engine in terms of vibration , power...?
Miroslav Karas
NYC
09/03/2007
Miroslav Karas
NYC
09/03/2007
RE: How about multiple expansion for internal combustion?
It's called a turbocharger.
To be more in tune with your question, it is the exhaust turbine side of the turbocharger hooked to ancillary drives or the drive line rather than a compressor.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The problem with using a second piston to expand the exhaust from the first cylinder is that the remaining energy is quite small, yet the frictional losses in the second cylinder will be /higher/ than those in the hp piston.
You also lose energy in the transfer port.
To be honest few IC engines are really designed for maximum efficiency, as fuel is cheap, and there are more pressing concerns.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
http://www
________
Andre' B.
different article:
http://ww
Rather that expanding in a second or third cylinder or in a turbine, some folks have proposed over-expansion in the same cylinder.
Probably the first to do this was Mr. Atkinson in the late 1800's. He had an engine cycle where the expansion stroke was twice as long as the compression stroke. Efficiency was better than competative engines at the time.
Ralph Miller proposed the Miller cycle in 1947. It uses valve events to make the expansion stroke effectively longer than the compression stroke, plus turbocharging to keep BMEP high.
j2bprometheus
Cheers
Greg Locock
http://www.gomecsys.com
I couldn't immediately work out why they needed to arrange the firing order in a way requiring a 1st order balancer shaft though.
Will be interested to see if this one takes off like all the other ones promise to...
