Survey of water well
A friend of mine has asked for some advice on performing a survey of a deep water well in Arizona. She needs to know the width, depth and other useful characteristics of the underground water supply. There are several six inch holes drilled down to the underground river to a depth of about 250 feet. She was referred to a company which does sonar imaging(sharkmarine.com) but they are located in Canada. What options are out their to perform this type of survey. I have no experience in this area so any advice or links to advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
RE: Survey of water well
Richard A. Cornelius, P.E.
WWW.amlinereast.com
WWW.amlinereast.com
Logs can measure the geometry (calliper logs), relative properties of the geology (gamma logs), soundness (sonic logs) etc. etc. You can run a down hole CCTV camera. What do you want to do , why do you want to do it and how much do you want to spend doing it ?.
You will also likely get more sensible answers than mine if you post this on the soil, groundwater forum
