Fiberglass Gasket
Fiberglass Gasket
Hello. I understand Fiberglass may be toxic. Can this material be used as gasket material for a Column internals? I am talking particularly about the tray downcomers, in which I have to bolt impingement baffles, for some process reason. The tray manufacturer is offering fiberglass gasket for this joint. The Impingement Baffles and Baffle brace are A-1011. The product in teh column is propane, Tdis: 204°C, Pdis: 12.76 bar. Thanks!
