Stainless steel application for Oily Water
I have the Oily water drain system.
oily water has 1500ppmw chloride and 10 ppmw sulfide and 44000 ppmw total dissolved solid at 45 deg C (atm).
We want to apply the SS 410 for pump (CA15) and tank.
Could any problem be occured in this condition?
If any problem could be occured, what is the recommended materials?
and more,
Is there reference for using stainless steel versus chloride limit?
and more,
RE: Stainless steel application for Oily Water
1. What is the recommended material for valve casing and trim?
2. How about carbon steel with epoxy coating for piping?
Coated material sounds like a good idea.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
We deside to apply coated steel for this condition.
hope this helps
s.
http://www.corrosionist.com
If you continually run into issues - and this is a pricey option, I would look into Ultimet alloy.
