Metal Hulls and Waterproofing Techniques
Hello all,
I'm curious about ways to make metal hulls (built from scratch) airtight and waterproof. I haven't built one yet but if anyone has could you please share your experiences? I want to build a remote controlled model (about 4' long) from metal to make it a deep diver and have more control over the size. My worry is how to prevent leaks as the pressure increases substantially (no pun). There must be some true and tested engineering techniques for connecting two halves of the hulls such that no spaces are left at the seams. Maybe glue a thin piece of rubber all around? Or maybe even de-pressurise the inside to suck the air out and force the hull-halves to stick together tighter?
Thanks!
--Max
Thanks!
--Max
RE: Metal Hulls and Waterproofing Techniques
Mike Halloran
Pembroke Pines, FL, USA
If you want to be able to split it again, buy a cheap water/explosion proof torch (Pelican do some really cheap ones) and look at how they use the O-Ring to keep it watertight. The secret is to design it so the water pressure squashes the O-Ring ever tighter, improving the quality of the seal when it is most needed.
What did you have in mind for through-water remote control?
A.
Mike, yes two 'canoes' design. This is a model so I want to be able to take it apart and fix/add/modify easily at anytime. Here are someone else's pictures to give a visual: http:/
zeusfaber, I like the O-Ring idea, thanks. I want them to stay joined but only when in water, of course :) Otherwise as I said above I want to be able to take it apart when I need to make modifications/adjustments e.t.c. so welding everytime would not be convenient.
One possibility - again stolen from the way real submarines are built - is to enclose all the stuff you need to keep dry in a smaller container which is designed purely to stay waterproof and resist pressure, then nest that inside a thin outer casing which needs do nothing more than look pretty/hydrodynamic/aggressive and to flood, vent and drain freely.
Some advantages to this approach are that
1. Your pressure hull can be optimised for being a pressure hull, with the shape chosen to minimise sealing and pressure resistance problems, and the size restricted to what you actually need.
2. Your outer casing can look as exotic as you like without your having to worry about watertight integrity and pressure resistance - and you can modify it to your hearts content.
3. Because the free-flood space between the pressure hull and the casing doesn't provide any buoyancy, you'll need much less ballast - vastly reducing the number of back injuries you suffer trying to get it home from the seaside.
A.
