ANSYS Coupled field analysis
Hi All,
I am doing a coupled field analysis(Structural-Thermal) in ANSYS 11.I face certain problems.I request your suggestions regarding the same.
Error Message obtained while running an analysis:
The Error message I got said ''equivalent plastic strain increment has exceeded the specified limit value.Since the time increment has reached the minimum value,the analysis is stopped''.
Problems faced:Result obtained not correct.
Thermal Load data is applied cyclic,I mean 2 secs of Temperature load and 300 secs of cooling applied through second input file.So Stress should increase when model is in cooling cycle.But in my model,stress doesn't vary,it never decreases at any time.do not know why.Please give me some hints why does stress value never drops down in this analysis?
The 3 materials used are Material 1 corresponds to Ceramic,second material to solder and 3 material to steel part.
INPUT FILE:
/BATCH
/BEGIN
!* 0. CONTROL PARAMETER
*set, R1, 7.5e-3
*set, R2, 18.5e-3
*set, h1, 13.55e-3
*set, h2, 4.5e-3
*set, h3, 0.5e-3
*set, h4, 15e-3
*set, N, 3
*set, factor, 1.0
*set, n_h1, nint(factor*N*h1/h3)
*set, n_h2, nint(factor*N*h2/h3)
*set, n_h4, nint(factor*N*h4/h3)
*set, n_R1, nint(N*(R2-R1)/h3)
*set, n_R2, nint(N*R2/h3)
*set, eps_s, 0.0010*h3/N
*set, eps_t, 0.0001*h3/N
*set,TREF,20
*set, NSS, 20
*set, NSSMAX, 100
*set, NSSMIN, 10
FINISH!*
!* 2. GEOMETRY & ELEMENT
/PREP7
ET,1,PLANE13,4,,1
k,1,0,0,0
k,2,R2,0,0
k,3,R2,h4,0
k,4,0,h4,0
k,5,R2,h4+h3,0
k,6,0,h4+h3,0
k,7,0,h4+h3+h2,0
k,8,r2,h4+h3+h2,0
k,9,r2,h4+h3+h2+h1,0
k,10,r1,h4+h3+h2+h1,0
k,11,r1,h4+h3+h2,0
a,1,2,3,4
a,4,3,5,6
a,6,5,8,7
a,11,8,9,10
aadd,3,4
!* ENDOF 2
!* 3. MESHPARAMETER
lesize, 1,,,n_R2,,,,,0
lesize, 2,,,n_h4,factor,,,,0
lesize, 3,,,n_R2,,,,,0
lesize, 4,,,n_h4,1/factor,,,,0
lesize, 5,,,N,,,,,0
lesize, 6,,,n_R2,,,,,0
lesize, 7,,,N,,,,,0
lesize, 8,,,n_h2,1/factor,,,,0
lesize, 10,,,n_h2,factor,,,,0
lesize, 12,,,n_h1,1,,,,0
lesize, 13,,,n_R1,1,,,,0
lesize, 14,,,n_h1,1,,,,0
lesize, 15,,,(n_R2-n_R1),,,,,0
!* 1. MATERIAL PARAMETER
*set, ro_stahl, 9900
*set, ex_stahl, 1.8e11
*set, nuxy_stahl, 0.3
*set, ctex_stahl, 11.7e-6
*set, c_stahl, 460
*set, kxx_stahl, 26
*set, emis_stahl, 0.0
*set, ro_lot, 7700
*set, ex_lot, 0.94e11
*set, nuxy_lot, 0.3
*set, ctex_lot, 18.0e-6
*set, c_lot, 185
*set, kxx_lot, 25
*set, emis_lot, 0.0
*set, ro_keramik, 3240
*set, ex_keramik, 2.9e11
*set, nuxy_keramik, 0.18
*set, ctex_keramik, 8.4e-6
*set, c_keramik, 662
*set, kxx_keramik, 35
*set, emis_keramik, 0.0
!* 4. ADJUSTMENTs FOR MATERIAL PROPERTY
mp, dens, 3, ro_stahl
mp, ex, 3, ex_stahl
mp, nuxy, 3, nuxy_stahl
mp, ctex, 3, ctex_stahl
mp, c, 3, c_stahl
mp, kxx, 3, kxx_stahl
mp, emis, 3, emis_stahl
mp, dens, 2, ro_lot
mp, ex, 2, ex_lot
mp, nuxy, 2, nuxy_lot
mp, ctex, 2, ctex_lot
mp, c, 2, c_lot
mp, kxx, 2, kxx_lot
mp, emis, 2, emis_lot
mp, dens, 1, ro_keramik
mp, ex, 1, ex_keramik
mp, nuxy, 1, nuxy_keramik
mp, ctex, 1, ctex_keramik
mp, c, 1, c_keramik
mp, kxx, 1, kxx_keramik
mp, emis, 1, emis_keramik
mptemp, 1, 20, 100, 200, 300
mptemp, 5, 400, 500, 700
tb, bkin, 2, 6
tbtemp, 20
tbdata, 1, 320E6, 0
tbtemp, 200
tbdata, 1, 300E6, 0
tbtemp, 300
tbdata, 1, 285E6, 0
tbtemp, 400
tbdata, 1, 260E6, 0
tbtemp, 500
tbdata, 1, 160E6, 0
tbtemp, 700
tbdata, 1, 20E6, 0
!* ENDOF 4
!* 5. MESHING
mshape,0,2D
mshkey,0
mat, 1
amesh,5
mat, 2
amesh,2
mat, 3
amesh,1
/SOLU
/SOLU
!* 7.1 BOUNDARY-, INITIAL-, LAST CONDITIONS & SOLVE
lsel, s, loc, x, -eps_s, +eps_s, , 0
dl, all, , symm, , 1
allsell, all
ksel, s, loc, x, -eps_s, +eps_s, , 0
ksel, r, loc, y, -eps_s, +eps_s, , 0
ksel, r, loc, z, -eps_s, +eps_s, , 0
dk, all, , 0, ,1, all
allsell, all
EQSLV,ITER,4
outres,all,all
!*6.1 Soldering Temperature Condtions
Antype,trans
tunif,20
autots,on
*set, temperature1, 500.0
sfl,2,conv,25,,temperature1 ! since line 1 is the bottom line.it is subjected to adiabatic heating condition.
sfl,5,conv,25,,temperature1
sfl,8,conv,35,,temperature1
sfl,12,conv,35,,temperature1
sfl,13,conv,35,,temperature1
sfl,14,conv,55,,temperature1
sfl,15,conv,35,,temperature1
nsubst,30,60,20
kbc,0
time,3600
outres,all,all
allsel,all
solve
time,7200
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,750
sfl,5,conv,25,,750
sfl,8,conv,35,,750
sfl,12,conv,35,,750
sfl,13,conv,35,,750
sfl,14,conv,55,,750
sfl,15,conv,35,,750
nsubst,20,50,10
kbc,0
time,8700
outres,all,all
allsel,all
solve
time,8820
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,930
sfl,5,conv,25,,930
sfl,8,conv,35,,930
sfl,12,conv,35,,930
sfl,13,conv,35,,930
sfl,14,conv,55,,930
sfl,15,conv,35,,930
nsubst,20,50,10
kbc,0
time,9960
outres,all,all
allsel,all
solve
time,10260
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,750
sfl,5,conv,25,,750
sfl,8,conv,35,,750
sfl,12,conv,35,,750
sfl,13,conv,35,,750
sfl,14,conv,55,,750
sfl,15,conv,35,,750
nsubst,20,50,10
kbc,0
time,12540
outres,all,all
allsel,all
solve
sfl,2,conv,25,,20
sfl,5,conv,25,,20
sfl,8,conv,35,,20
sfl,12,conv,35,,20
sfl,13,conv,35,,20
sfl,14,conv,55,,20
sfl,15,conv,35,,20
nsubst,20,50,10
kbc,0
time,16140
outres,all,all
allsel,all
solve
endtime=16140
KBC,0 ! STEP BOUNDARY CONDITIONS
DELTIM,100 ! MINIMUM TIME STEP
TIME,endtime ! TIME AT END OF TRANSIENT
OUTRES,all,ALL
!* 6.2 Thermal Load conditions
AUTOTS,ON
*do,i,1,5
endtime=endtime+2
time,endtime
Deltim,0.1
dl,13,,temp,1300
dl,14,,temp,1300
dl,15,,temp,1300
SFL,2,CONV,25,,300
SFL,5,CONV,25,,300
SFL,8,CONV,35,,300
SFL,12,CONV,35,,300
solve
dldele,13,temp
dldele,14,temp
dldele,15,temp
endtime=endtime+300
time,endtime
Deltim,10
SFL,13,CONV, 35 , , 300
SFL,14,CONV, 35, , 300
SFL,15,CONV, 35 , , 300
allsel,all
solve
*enddo
solve
/Fini
Thank you
Kind Regards
Anjali
INPUT FILE:
/BATCH
/BEGIN
*set, R1, 7.5e-3
*set, R2, 18.5e-3
*set, h1, 13.55e-3
*set, h2, 4.5e-3
*set, h3, 0.5e-3
*set, h4, 15e-3
*set, N, 3
*set, factor, 1.0
*set,TREF,20
*set, NSS, 20
*set, NSSMAX, 100
*set, NSSMIN, 10
FINISH!*
/PREP7
ET,1,PLANE13,4,,1
k,1,0,0,0
k,2,R2,0,0
k,3,R2,h4,0
k,4,0,h4,0
k,5,R2,h4+h3,0
k,6,0,h4+h3,0
k,7,0,h4+h3+h2,0
k,8,r2,h4+h3+h2,0
k,11,r1,h4+h3+h2,0
a,1,2,3,4
a,4,3,5,6
a,6,5,8,7
a,11,8,9,10
aadd,3,4
!* ENDOF 2
!* 3. MESHPARAMETER
lesize, 5,,,N,,,,,0
lesize, 7,,,N,,,,,0
*set, c_stahl, 460
*set, kxx_stahl, 26
*set, ro_lot, 7700
*set, nuxy_lot, 0.3
*set, c_lot, 185
*set, kxx_lot, 25
*set, emis_lot, 0.0
mp, ex, 3, ex_stahl
mp, c, 3, c_stahl
mp, dens, 2, ro_lot
mp, ex, 2, ex_lot
mp, c, 2, c_lot
mp, kxx, 2, kxx_lot
mp, c, 1, c_keramik
tb, bkin, 2, 6
tbtemp, 20
tbdata, 1, 320E6, 0
tbtemp, 200
tbdata, 1, 300E6, 0
tbtemp, 300
tbdata, 1, 285E6, 0
tbtemp, 400
tbdata, 1, 260E6, 0
tbtemp, 500
tbdata, 1, 160E6, 0
tbtemp, 700
tbdata, 1, 20E6, 0
!* ENDOF 4
!* 5. MESHING
mshape,0,2D
mshkey,0
mat, 1
amesh,5
mat, 2
amesh,2
mat, 3
amesh,1
/SOLU
/SOLU
allsell, all
allsell, all
EQSLV,ITER,4
outres,all,all
Antype,trans
tunif,20
autots,on
nsubst,30,60,20
kbc,0
time,3600
outres,all,all
allsel,all
solve
time,7200
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,750
sfl,5,conv,25,,750
sfl,8,conv,35,,750
sfl,12,conv,35,,750
sfl,13,conv,35,,750
sfl,14,conv,55,,750
sfl,15,conv,35,,750
nsubst,20,50,10
kbc,0
time,8700
outres,all,all
allsel,all
solve
time,8820
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,930
sfl,5,conv,25,,930
sfl,8,conv,35,,930
sfl,12,conv,35,,930
sfl,13,conv,35,,930
sfl,14,conv,55,,930
sfl,15,conv,35,,930
nsubst,20,50,10
kbc,0
time,9960
outres,all,all
allsel,all
solve
time,10260
kbc,0
nsubst,20,50,10
outres,all,all
allsel,all
solve
sfl,2,conv,25,,750
sfl,5,conv,25,,750
sfl,8,conv,35,,750
sfl,12,conv,35,,750
sfl,13,conv,35,,750
sfl,14,conv,55,,750
sfl,15,conv,35,,750
nsubst,20,50,10
kbc,0
time,12540
outres,all,all
allsel,all
solve
sfl,2,conv,25,,20
sfl,5,conv,25,,20
sfl,8,conv,35,,20
sfl,12,conv,35,,20
sfl,13,conv,35,,20
sfl,14,conv,55,,20
sfl,15,conv,35,,20
nsubst,20,50,10
kbc,0
time,16140
outres,all,all
allsel,all
solve
endtime=16140
OUTRES,all,ALL
AUTOTS,ON
*do,i,1,5
endtime=endtime+2
time,endtime
Deltim,0.1
dl,13,,temp,1300
dl,14,,temp,1300
dl,15,,temp,1300
SFL,2,CONV,25,,300
SFL,5,CONV,25,,300
SFL,8,CONV,35,,300
SFL,12,CONV,35,,300
solve
dldele,13,temp
dldele,14,temp
dldele,15,temp
endtime=endtime+300
time,endtime
Deltim,10
allsel,all
solve
*enddo
solve
/Fini
Thank you
Kind Regards
Anjali
