Rain covers within plant structures? acceptable pratice?
In a plant design I am reviewing it is proposed to have several roofs within the plant structure. They are for rain protection while operators change filters. The chemical manufactured in the area will not meet customer specs if it gets wet. It also makes the operators job easier.
These are typically 2 m width by 10 meters long. Only a roof no sides or walls. So.. are they any guiding layout codes or safety codes i should check?
the materials we make are typiclly flash point 55 C, to -5 deg C depending on area. Covered areas are only flash point of 55deg C or higher.
I think its ok.. so far i have checked internally and found no objectections but we are still working through the reivews..
i am really after where i s hould constult a safety manual or design codes?
RE: Rain covers within plant structures? acceptable pratice?
My only real comment is to pay attention to possible restrictions to access for equipment maintenance or replacement in the future, especially overhead lifting requirements.
It is possible that you may have company standards to contend with, so check all of those.
http://virtualpipeline.spaces.msn.com
