Remediation of Misaligment
How do I remediate/repair a misaligment of abutting ends?. The offset exceds 1/8. The pipe have the same NPS. Thanks.
CorpMex.
CorpMex.
RE: Remediation of Misaligment
Hi Metengr,
The offset of misalignment is at a circunferencial weld of two pipes NPS 6 std.
Octavio.
To do this, one can locally trim and introduce a counterbore on the ID surface of the pipe at the weld prep region. If the wall thickness after counterboring falls below minimum wall, one can extend the weld cap to restore the wall thickness.
http://www.pipefitter.com/Tools.html
