water ring pump
water ring pump
water ring pump
I want to build a water ring pump with perssure ratio of 1 to 4 (bar) I want to calculate its efficiency before building it and also its other parameters such az inlet and outlet pipe diameters with respect to its efficiency but I have not found any basic about this calculation on this pump perticularly and no special scientific paper.only industrial.if you give me any help or link to solve this problem I ll be regardfull.
