Copying views in a drawing
I have an assembly and I have made three different displays states.  The first display state shows the assembly in it's entirety.  The next two, show two different sub assemblies with everything else hidden.
I have a drawing detailing the entire assembly with the standard three views.  However, I want to detail the other two display states, which I need two more elevation views.  How can I get two more elevation views in the drawing at a larger scale (1:4) in addition to the existing elevation view (1:8)?
Thanks!
J.D.
RE: Copying views in a drawing
Click on the Projected View icon, then select the view you want to make additional views/elevations from. A view will be created dependent upon which direction you move the cursor.
Before placing the view, the scale can be set via the View Managers Use Custom Scale option.
cheers
I was able to RMC on the drawing and click >Drawing Views > Model and bring in a new view, scaled correctly with the right display state and the bubbles follow the BOM.  I will try your way as well.  Thanks!
woohoo, this is a breakthru for me!
J.D.
