Coating a Bellmouth on GE Frame 6
What are the benefits of coating a Bellmouth and can it be quantified?
I know that properly coating surface can help with airflow and anti-fowling. Also, coating can reduce corrosion in high humidity areas.
Lately, I have heard that efficiency gain (improved airflow) is negligible and corrosion is the primary reason for why to coat a Bellmouth.
CE
CE
RE: Coating a Bellmouth on GE Frame 6
a) It looks better.
b) Helps protect
c) It keeps business in trade!!
Quantifying the performance benefits would be a non-rewarding task with negligiible results.
