concentrated load on slab over form deck
I would like to find a reference to check a concentrated wheel load for a 3.5" LW concrete slab over 28ga form deck. Has anyone come across a reference with eqns./commentary on this subject?
RE: concentrated load on slab over form deck
h
Composite deck takes a poriton of the load, so the example is not quite the same.
For comparison, Hambro has published a similar procedure for solid slabs in thier Technical Manual. Hambo says its procedure appears in Section 317 of the British Standard Code of Practice CP114.
