Steel sheet as lateral restrain?
Can I take into account steel sheet (thicknes=4mm) as a lateral restrain against torsional buckling?
Thank you in advance.
Drile007
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Steel sheet as lateral restrain?
Dik
What kind of structural shape are you talking about here?
"Sheesh. Some days it just doesn't pay to get out of bed."
effective."
If it is a torsional buckling mode, it's twisting restraint that is needed not lateral.
Dik
Mike McCann
McCann Engineering
Lateral restraint - yes
Torsional restraint - no.
Even if the plate can technically support the required bending moment it would be too flexible to eliminate torsional effects.
csd
