We resume work tomorrow
When we discharge (or load) heavy cargoes, it's always preferred to do it with daylight.
Let's say that after loading two piece the next three are left for the next day.
What should I say? Loading was "deferred" or "postponed"?
Is it any difference between both expresions?
Agustín Tomás
RE: We resume work tomorrow
I would go with "deferred".  This indicates to me that the activity was delayed for an arbitrary and non-critical reason.  "Postponed" would indicate to me that there was a serious problem that causes a delay.
"I will defer this activity until tomorrow because I need sleep."
"I will postpone this activity until next week because the machine is broken."
But they are almost equivalent.  In American English, I think either one would work just as well.
TygerDawg
Blue Technik LLC
Advanced Robotics & Automation Engineering
www.bluetechnik.com
Deferred or postponed suggests that there is a delay vs some initial planning, but in your case there is none since you "always" load in daylight.
So I would just say "loading continues tomorrow".
(waiting for more eloquent people to throw in another dozen of variations to the theme! smile )
How about "suspended?"
Deferred or postponed are essentially equivalent.
But in management-speak, both could be viewed as a delay.  Why not put a positive spin on it, the title of your post is perfect.
We resume tomorrow.
Interrupted, say, by darkness?
Mike
I have to agree with epoisses' post.  Something like "Loading continues at daylight tomorrow" would work.
"Postponed" and "deferred" both suggest to me a delay in starting rather than something that comes partway through.  If there's any difference between them, I think it's that I'd apply "postponed" more to an event, and "deferred" more to an activity.
"Interrupted" often suggests an unexpected break, while "suspended" is something I would normally use more if I wasn't sure when conditions would be right for work to resume.
How about "stopped for the night"
A.
Actually, loading is neither "deferred" nor "postponed". If something takes 2 days, it takes 2 days.
I would just say that "loading is under way, 2 out of 5 completed".
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
I agree with Ashereng. Neither deferred nor postponed is correct. That would imply that the entire loading operation would be deferred to the next day. But in fact an ongoing operation was interrupted due to bad light and will resume the next day.
A load is always suspended until it is dropped, just like this post should be. bigsmile
Mike McCann
McCann Engineering
"We resume work tomorrow"
Is that a French phrase?
loading will be finalised tomorrow.
If it's a union operation, it needs no explanation.
"We're done for the day and you're lucky you got what you did."
Timing has an awful lot to do with the outcome of a rain dance.
If it was union, they would put up their 10 min break sign and then come back in the morning.
Tobalcane
"If you avoid failure, you also avoid success."
