Cross sectioning view of an object
I did stress analysis on an object with several components stacking up. I'd like to see the stress distribution within the object along the diagonal. what commands should I use to create this cross sectioning view?  Thank you!
RE: Cross sectioning view of an object
Check out the following commands:
/CPLANE
/TYPE
Thank you.
