#Value error when setting a Cell value
I'm a newbie to Visual Basic on Excel. I wanted to do a very simple task, and have wasted a couple hours trying. I'm hoping somebody can help. Here is a very simple function, but I get #Value error when I use it.
Function Test()
' The following doesn't work - I get a # Value error: WHY
[A2].Value = 34
' The following does work:
Test = [B2].Value
End Function
Function Test()
[A2].Value = 34
Test = [B2].Value
End Function
RE: #Value error when setting a Cell value
TTFN
Maybe I should provide some more details in case I'm missing something very fundamental. In Excel I selected Tools->Macro->Visual Basic Editor. I then picked 'Insert->Module' and put the code in the module.
Thanks again for the feedback.
Referring to Cells by Using Shortcut Notation
You can use either the A1 reference style or a named range within brackets as a shortcut for the Range property. You don't have to type the word "Range" or use quotation marks, as shown in the following examples.
Sub ClearRange()
Worksheets("Sheet1").[A1:B5].ClearContents
End Sub
Sub SetValue()
[MyRange].Value = 30
End Sub
TTFN
This is disappointing, but I need to move on to plan B so I can finish my task. I will continue to investigate this in the background, because I think this kind of VB programming in Excel will be useful to me, if I can get it to work.
Some things are not making sense. Your above code is a function, not a subroutine. How are you calling the function? If you are trying to set a cell value with a user defined function, then you would use
Function Test()
Test = [B2].Value
End Function
then in your spreadsheet, you would set the formula for cell A2 to =Test which in turn makes its value equal to the value of B2
If my memory serves me correct, you can't change the value of other cells with a user defined function
Thanks for the feedback. What you described works, as I mentioned in my original post. However, you mention "you can't change the value of other cells with a user defined function". That is exactly what I want to do. IRstuff said it worked on his computer.
I ran the function in the VB debugger, and it worked. However, when I use it in the spreadsheet it doesn't work. Maybe the problem is, as you say, "how I'm calling the function". I am just putting '=Test()' in a cell. Is there another way to call the function? As I said, I'm a newbie at doing VB in Excel, and I'm probably doing something dumb.
Thanks again for your help.
Thanks again
Thanks for your help CFCEng and IRstuff.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
