Bullheading Pump
Bullheading Pump
Bullheading Pump
Hi;
For one of our project we need a diesel bullheading pump and we decided to use reciprocating API 674 type for this application. (High pressure pump for opening SSSV valve)
I found some of the reciprocating pump vendors but actually I prefer to work with someone who has experience in bullheading package.
Dose anybody have any updates on that?
Regards;
RE: Bullheading Pump
Please explain bullheading.
Inject high pressure diesel into an oil or gas well for pressure equalising of a closed SSSV (Sub Surface Safety Valve) called as Bull Heading.
Thanks for the explanation
We have an (old) electric driven recip pump in this service from Duraqual, try www.pumpingequipment.com.au. Not sure of their packaging experience/capability for diesel drives though.
Good luck.
 The Halliburton HT400 is the most common type used in the oilfield for pumping cement , fracturing and bullheading.Can be diesel or electric drive , about 400 kw
