Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say that you guys RULE, a million thank you's to whoever created, and/or manages this site. KEEP UP THE GOOD WORK..."
Geography
Method for load sharing in multiple drive-unit assembly
Gerry45 (Mechanical)
30 Aug 07 15:20
I have a large and heavy piece of industrial equipment that is rotated into different angular positions via a 2m dia gear ring. The gear-ring is driven by the output pinions of six electric motor powered gear units positioned around it.
The system works well under power because the six gear-units share the load evenly. However, when not driving, shock loads from the equipment tend to travel back to the drive-units. Unfortunately because the ratios of the drives make them non-reversible, differences in drive-unit backlash together with differences between ring-gear and drive-pinion backlash seem to concentrate the loads on some (or perhaps one!) of the drive units. This can result in breakage of teeth in the ring-gear, drive pinion or drive-units.
Solutions to even out the 'reverse' loads could include the fitting of slipping clutches etc. However, because such things could result in reduced controlability of the system I'm reluctant to go this direction. So Im aiming to try to make the best of the existing set-up, if possible.
It may be possible to ask the drive-unit maker to match the units for backlash. But that still leaves me with some variability due to the radial tooth-runout of the ring-gear relative to the positions of the six drive units.
Does any one know if there is a special (but robust) geartooth profile available that would be much less sensitive to the radial runout of the ring-gear and therefore provide more even load sharing on the six drive-pinions ?
I hope I have explained this clearly, if not please let me know.
Gerry
tbuelna (Aerospace)
30 Aug 07 21:37
Mount the ring gear with a flexure or mount the drive motors on a common plate that floats within the ring gear.  The torsional forces can be taken out with a drag link.
gearcutter (Industrial)
30 Aug 07 23:05
Mesh a single pinion with the ring gear. The pinion is then set up as a free wheeling idler while the system is operating. Design the pinion so it can handle the load on its own. Design a possitive locking brake that will lock the pinion while the system is idle.
eromlignod (Mechanical)
31 Aug 07 9:17
How about locking the ring with a brake so that you're not relying on the drives to hold the machine in place?
Don
Kansas City
Close Box
Join Eng-Tips® Today!
Join Us             Close
