When to use Sanitary/Food Grade Piping
I am starting a project on a chemical plant in Washington and I have been told some of the product may be used as a food additive.
My question is this: Can anyone direct me to the Spec. that will tell me if or when Food Grade piping and vessels will be required.
Any helpful responses or advice would be greatly appreciated.
RE: When to use Sanitary/Food Grade Piping
I work for a consultancy company that does a lot of work for food industry clients and typically the client would specify what pipework they want installing.
If I understand correctly - you're company produces chemicals and one of your customers uses your products as an ingredient. I think that the FDA would require material traceability from the food manufacturer and they would request this of you - therefore they would be telling you when food grde piping is required.
If it is frequent (once a week?), I'd go with the sanitary fittings since they are easy to disconnect and reconnect.
If your process is continuous with little chance of contamination (due to acidic nature for instance), I'd go with regular piping (flanged and welded).
On welds though, make sure you specify to grind and/or polish them on interior surfaces so that you don't get pockets of material that can hang out for a while and ferment or become contaminated.
Talk to your tank manufacturer about what grades they offer and the costs associated with each. They will generally have built something previous that is similar to your needs.
