Balloons have vanished?
I have a section view and I had added about 5 balloons.  Now the balloons are gone.  When I check the BOM contents it shows there are balloons attached to those 5 items But I don't see them.  I checked my layers and they are all on.  Is there something else I could try?
RE: Balloons have vanished?
These would be my first guesses (unless I'm missing something very obvious):
Rebuild drawing using CTRL-Q.
Rebuild the assembly using CTRL-Q while the drawing is open.
Close and reopen drawing.
Check to see if there are any graphics driver issues or updates.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
This happens on larger assemblies to me also. Ctrl-q  will bring them back but they will go away again at random it seems. I am not sure of the overall fix. The above may be the work-around. It is frustating as it appears to happen with no reason. I end up redoing the ballons and then double balloons show up.
It definitely seems to be related to large assembly drawings.  Ctrl-Q won't even bring them back.
With the lack of other responses here, I suggest contacting your VAR about the issue.
Matt
Silicon Valley, CA
sw.fcsuper.com
Which graphics card and driver are you using?
cheers
I've had this same problem with large assemblies. Turns out SolidWorks would hide them for some reason, and a 'show annotations' would bring them back.  Also, I had my drawing view locked.  When I unlocked it and moved it slightly, the balloons would appear again.
John Graham CSWP
Mechanical Design Engineer
Quadro FX 1100
Time to update that driver. That one is not certified for 2007.
cheers
