Looking Siemens, CEMP, ABB Motor Supplier
I have some class 1 / div 1 exp motors that I need to replace but having a hard to find them
The manufacturers are Siemens, CEMP SPA and ABB.
Can anybody suggest a reputable place to contact?
Prefer USA or EU supplier. Motors are to shipped to and used in West Africa
RE: Looking Siemens, CEMP, ABB Motor Supplier
US Motors is an option. But these would be NEMA frame.
http://www.usmotors.com/default_products.htm
Toshiba USA makes a lot of motors in Houston area - not sure if they do Exp-Proof or not.
GE still makes motors also.
http://www.siemens.com.ng/en/s_nav23.html
They will offer (typically) European versions of motors due to the supply frequency at 50Hz but can get NEMA motors shipped in from the US.
If you are looking for the US contacts for explosion proof motors, then try:
ht
Siemens are a pretty global company so wherever you are you should find somebody willing to help.
I guess the same is true for ABB but I don't work for them.
FYI we a a real variety here, 50 and 60Hz and Nema / IEC.
adds to the challenge
If you send on the info I can put you in contact with a company in Europe that can offer SIEMENS and maybe CEMP, they would be IEC frames in 50 or 60hz.
