Mechanical Test
Mechanical Test
hi guys
If carbon steel Pipe(EFW)would be required PWHT after Welding.
When would be tested mechanical test(T.S, Y.S, E.L, Hardness)
Thickness of Carbon steel pipe is 12.7mm with longitudinal welding seam.
Is it no problem that if mechanical test would be tested before PWHT.
thank
thank
RE: Mechanical Test
Review the various ASTM/ASME specifications for seam welded pipe;
ASTM A (or ASME SA) 671
ASTM A (or ASME SA) 691
RE: Mechanical Test
Again, review the necessary ASTM/ASME specifications for welded pipe.
RE: Mechanical Test
