how to handle coiled tubing in assembly
I have tubing that I have modeled as a long, straight tube. Is there a way to easily coil that for an assembly? Using a configuration comes to mind, but like sheet metal, I was wondering if there were an easy way to call something a "flexible tube" and wrap it around a hub of a known diameter.
Matt
Matt
RE: how to handle coiled tubing in assembly
Probably the simplest way is to make a separate model using a Sweep along a Helix. You could make a config within the existing straight tube part and do the same thing. One config suppressing the straight and another suppressing the coil.
Regards.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
