Vibration Response Problem
Hi
I am a new user to ansys. I want to calculate the vibration response of a simple supported beam. I used the transient dynamic analysis and POST1 for the calculation of strain of all the elements
i used ETABLE command to calculate the strain
i want to calculate the strain for different values of the load. however, i get the same strain values for every load case.
can you please help me to get the correct solution
RE: Vibration Response Problem
Maybe you should try spectrum analysis, which is usually used for vibration analysis.
Rock Li
