Simple guides for pipeshoes
Is there someone out there who knows a very simple guide-construction for pipeshoes on a HEA beam?
For contractors to make them, not to buy somewhere.
Preferrably without drilling in the beam.
Thanks in advance
Thanks in advance
RE: Simple guides for pipeshoes
If you want something both permanent and able to sustain a reasonable lateral load, I think you may have to accept welding or drilling.
Jobs are too small to order these, but I think they are too complex to make for the contractors.
The contractors here are in the possession of bolts and nuts pipes and flat steel approx. 30x4 to 100x6mm.
I´d rather use this material for guiding.
I´m starting here to introduce supporting on drawings instead of improvising by contractors.
The knowledge of supporting is minimal.
Almost everyting is fixed supports with the consequences (routing with curves).
