A-Arm Buckling end conditions?
Hi I was wondering what the proper Euler Buckling end conditions would be for a individual tubular a-arm link would be. The links are welded to a steel boss with a spherical bearing. The other end of the link has a threaded rod end attached to it. I am thinking that you can assume that the end with the rod end is a pinned joint (no moment support) and the end at the ball joint is fixed. Therefore the effective length would be .7L. Or would a model with both ends fixed be more accurate (ie. effective length of .5L)?
Thank You
Thank You
RE: A-Arm Buckling end conditions?
Shouldn't really matter unless you have an extraordinary design, I've worked on very few suspension parts where buckling was a big design issue (two, from memory, neither were A arms).
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Given that arms do occasionally get bent it pays to be ultracautious.
Cheers
Greg Locock
