Edit break lines in draft???
Is there any way of editing break lines in draft mode once you hit the "Finish" button??? I did a copy of an existing Draft and Assy and all that changed in the model were the hole locations.... of course, the new holes do not show up because they fall in the break.... Is there a way to move those break lines or do I need to redo the views and redimension the entire assy????
SE V15....
Tom....
thanks!
SE V15....
Tom....
thanks!
RE: Edit break lines in draft???
select the view containing the break. Then the rightmost button
on the ribbon bar can be clicked and the break will be editable
again, just select it when it's displayed again
dy
