Keeping it real in 3D
Hi!
Is there a trick for dimensioning in a 3D sketch? I finally had to create an "offset/through point" plane to dimension the true distance in X. It kept wanting to grab a vertex, edge, or face, and create a kittywompus dimension!
Ken
Ken
RE: Keeping it real in 3D
You can also click on the dimension and then select and drag the end point of a leader line to change the rotation.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
