Detail Function in Solid Works
I imported a dxf file into solid works.
I am attempting to create a detail view from
a portion of a larger view. The detail icon is
not enabled. Why?
not enabled. Why?
RE: Detail Function in Solid Works
Heckler![[americanflag] americanflag](https://www.tipmaster.com/images/americanflag.gif)
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
o
_`\(,_
(_)/ (_)
"Avoid the base hypocrisy of condemning in one man what you pass over in silence when committed by another." -- Theodore Roosevelt
Are any other icons greyed out?
Can you create detail views from drawing views of other parts?
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
