text from a cell to VBA
Hello everybody,
I need help. I'm making a VBA code to work with an excel sheet. One of the functions of the VBA code is to do something depending on the value of a cell. The value of the cell is a text value, if the cell reads "END" then the code has to do something. The problem is that when I input the word END to the cell the code does not work, but if i input: ="END" then the code works. In my first attempt to make the code everything worked fine, but then I deleted a column that I wasn't using and the problem with the text in the cell started. I don't know if I moved something by mistake but I don't seem to make it work again.
Please help me because I ran out of ideas.
Jose Luis Walters.
Jose Luis Walters.
RE: text from a cell to VBA
CODE
MyInput= Range("A1").Text
Dim FinalRow As String, NextRow As Integer
FinalRow = Range("A1000").End(xlUp)
If FinalRow = "FIN" Then
Sheets("S2").Select
NextRow = Worksheets("S2").Range("A1000").End
(xlUp).Row + 1
Worksheets("S2").Cells(NextRow, 1).Select
End If
I'm using the word "FIN", END in spanish, and my version of office is in english.
The code has to detect the last used cell in column A and if the text in the cell reads "FIN" it has to select the next empty cell in column A in sheet "S2". But i have to input ="FIN" to the cell to make it work, but like I said in my first attempt it worked fine with just writing FIN into the cell.
Your code works fine on my machine even using END
Go figure...
Can anyone help me with this problem?
TTFN
Try using the Change event instead of the Calculate event. Or use both if you need to.
Jose Luis Walters
