Cryogenic, Low Pressure RV
Anyone know of a RV that can do this?
Inlet: 2"
Outlet: 3"'
Media: Helium gas
Temperature range: -440 F to 70 F
Set Pressure: 0.25 psig
Flow Required:  12,000 SCFH at -300 F
RE: Cryogenic, Low Pressure RV
Just off the top of my head I would say talk to protectoseal.   You really might want to go with a buckling pin if you are not setting it off all the time.  Look at the  PIN-TECH BUBBLE-TIGHT < 500 PPM, PRESSURE RELIEF VENT
Series No. 56000
My two cents
StoneCold
Thanks SC.  I called them up, and although they don't have any cryogenic RV's, they seem interested in designing something.
Any other leads would be appreciated.
You might have trouble with the -440F.  It seems more common for cryogenic valves to stop at around liquid nitrogen temps, around -325F.  Other problem is the extremely low 0.25 psi set pressure, that's uncommon as well.
http://www.regoproducts.com/cryoflow/cg/pdfs/relief.pdf
Not sure how low the Flowsafe valves go.  http://www.flowsafe.com/cry.htm
http://taylorvalve.com/ can make you a valve with materials accepted for cryo service, but they haven't tested them that way.
Best bet is probably an austenitic stainless body, like 316 SS.
Other materials to look for: Hastelloy, Inconel, Monel, aluminum (tho I haven't seen any Al valve), bronze/brass.
Only seal material I know of is teflon, but I've seen lots of different numbers on the lower temp limit.
Good luck.
