How to pronounce "wythe"
I have a brick wall
It has a wythe
Does it rhyme with with
or does it rhyme with "why th"
It has a wythe
RE: How to pronounce "wythe"
The correct pronunciation is your option 2.
"If you are going to walk on thin ice, you might as well dance!"
http://dictionary.reference.com/browse/wythe
It also appears to be a typo or alternative spelling for for "withe" or just "with". Is this an document you are referencing?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
That's a different word. Wythe County, Va is indeed pronounced with. The word JAE is interested in is only used for a leaf of masonry, and is pronounced why th. One of those words the layman (and probably the mechanical engineer) never encounters.
Was that a haiku?
DaveAtkins
Running bond with lime mortar
Crumbles into dust.
Not intentionally. I'm German in background - not Japanese.
I left the link for all of it's references, not just the first one. The last entry shows "same as withe". Under withe, there are three pronounciations: two variations of with, and one with the long I sound. These words all likely have the same origin in one way or another. Besides that, the name of the county would come from a persons last name, which would come from that person's forefather's career. Names do get mangled over time, but given the other references, it would appear "with" is more common pronunciation, but that both are correct. This is all original research though, because I can't find a direct reference to the pronunciation in the context of masonry.
Anwyays, my guess is that either pronunciation is correct, but "with" is more common.
Matt
Silicon Valley, CA
sw.fcsuper.com
If you are talking about masonry, it's wythe, with a LONG 'I'. Take it from an architect with a family of stone and brick masons going back generations.
I don't know what these other so-called references are talking about. How do they want you to say a similarly-spelled construction term, wye connection? 'wih' connection, 'wee' connection?
Width — The dimension of a member measured in the
plane of a cross section parallel to the neutral axis.
Wythe — Each continuous vertical section of a wall,
one masonry unit in thickness.
wh I th
My Wythes sound like a Y that is spelled like Wye, but looks like a width to I.
"w-eye-th".
Please excuse my spelling and punctuation.
Mike McCann
McCann Engineering
