Opto 22 PCI AC5 with VB .NET
Guys,
   Has any one ever used a Opto 22 PCI AC5 card with Visual Basic .Net?  I can get it to work in VB6. I have tried using it with VB.net 2005.  I could not directly add a reference to the .dll that comes with the card (OptoPCI.dll) - check accessability .. valid assembly/com component error. Tried using Tools->Upgrade VB6 code on the .bas file that is suppose to be added to VB6 projects. Tried TlbImp.exe and received "not valid type library" error. Any suggestions would be much appreciated.
