Change/apply Document Properties to an Assembly parts
How can I change/apply Document Properties to the whole assembly including parts in the sub-assemblies?
Michael Fernando
Tool and Die Designer
SWX 2007 SP2.1 X64
PDMWorks 2007
Logopress3
FastForm Advance
FormatWorks
RE: Change/apply Document Properties to an Assembly parts
<http://www.esoxrepublic.com/freeware/index.html>
There are macros to copy custom properties and to populate material properties through an assembly. Perhaps combine them?
Otherwise, there are other macros out there for copying properties and populating properties through multiple files.
See <http://www.customsolids.com>
http://www.EsoxRepublic.com-SolidWorks API VB programming help
PropertyEditorGlobal from http
SWcp3 from http://www.swcp3.com/
Update Custom Properties from within the SW Task Scheduler
I want to change and apply Detailing /Dimensioning Standard and Units to the Main Assembly and the entire subassemblies, part files.
Thanks for your help.
Michael Fernando
SWX 2007 SP2.1 X64
PDMWorks 2007
Logopress3
FastForm Advance
FormatWorks
Only does one file at a time though.
