HOLE TABLE UPDATE QUESTION
Ex: one hole is .100 blind and another is .100 thru. Hole table is formed and it lists each as separate line items, which is fine.
If I go back and change the thru to a blind hole, the thru remains for the hole description.
Similarly, if I have one .100 hole and one .125 hole in the hole table and the .125 changes to a .100, there will still be two line items for .100 hole, each having a different tag.
Does Solidworks just not consolidate hole tables all too well, or am I missing something?
RE: HOLE TABLE UPDATE QUESTION
