Infrared Pyrometer
Infrared Pyrometer
Infrared Pyrometer
I am looking into the possibility of measuring certain objects as they are placed into heated dies.
If the objects are left in the dies too long then the chemical on the top surface starts to react before they can be processed.
The color of the object is medium green I am sure that the Emissivity level will be .9 or better.
I would need to scan the objects from a distance of 1 meter.
James N.
