Building pressure relief
Typically, I've been designing HVAC systems where the return air is about 80 - 90% of the supply air so I have not been worrying about building pressurization. However, now I have a church with a vav ahu and a significantly reduced RA flow. So I have a few questions:
1. At what point do you want to start looking at including some pressure relief into your design?
2. I'm located in Florida and most of the buildings I have seen do not have relief fans or exhaust fans for pressure control. I have seen relief dampers. Why would you choose a fan over a relief damper?
3. For my design I have a ducted return system. The limited mechanical room space is going to eliminate the fan option. So them am I left with a relief air damper and transfer grilles in every room?
Thanks for your help!
RE: Building pressure relief
One side note, are you following an occupancy schedule with your OA or controlling it by CO2 levels? A church typically has high occupancy for a very shorty period of time and then minimal occupancy for the rest of the time.
