Mirror of part needed to be a separate part
I modeled a solid using Catia V5R17 and I need the mirrored version as a separate part. How do I mirror the solid into a separate part? Is there a way to keep associativity?
Thank you,
Jeff
Thank you,
Jeff
RE: Mirror of part needed to be a separate part
Insert your part. then while working in the product, go to the top of the window and goto Insert->Symmetry. Choose the plane of symmetry, choose your part from the tree, Choose your options in the dialog box. Ok.
Save management. done.
Let us know if that worked for you.
--Jay
That's also a great way to do it. I like that method.
