Simple fail proof overtemp protection
I've got an AC circuit that draws about 2A. What I need to do is cut the power to the device should a transistors heat sink overheat (defined as >100C). Preferably until the user unplugs the unit, or at least until it cools down some amount (20C?). It should be resettable, not permanent.
Simple solutions are usually the best, but unfortunately digikey only carries a to-220 thermal switch that can handle 1A, not the 2A required.
So I was thinking of either finding a way to boost the current capacity of it, or building a comparator with a NTC/PTC resistor and a voltage divider to set the trigger point. Maybe controlling a triac? I don't remember how triacs work; never even used one.
Any "battle tested" suggestions would be most helpful.
RE: Simple fail proof overtemp protection
http://www.sensata.com/about/klixon.htm
http://www.farnell.com/datasheets/95815.pdf
I don't have an attitude problem. You have a perception problem...
I think the polyswitch won't work; I haven't seen one that can handle both the voltage and the current (1-2A@90 up to 240Vac)
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
xnuke - thanks! That's certainly another option to look into.
You control the transistor's base/drive NOT the main switched power.
Does this thing have a micro controller involved?
Keith Cress
Sometimes I wake up Grumpy.
Other times I just let her sleep!
Last defence is what fuses are for.
Having a temp switch that maybe turns your problem ON and OFF randomly is not a solution.
If you need last defence protection you need a thermal fuse.
They make transistor based circuit breakers now.
Keith Cress
Keith Cress
