Heater for LPG Liquid
It is late at night, eyes are getting heavy and I do not find anything on google. So I ask here.
The problem is offloading of -42°C LPG from a marine tanker to onshore storage at 500 cubic meters per hour. The storage terminal will accept LPG liquid only with approx. 3°C. A heater against seawater has been chosen. My question is whether there are also heaters against air for this duty?
The LPG is going into quite a long 10" pipeline from the jetty to storage. I would find it quite a pity that all that length could not be used to realise perhaps a finned convectional heater. Or would it have to be forced/induced draft finfan? Or a package of finned tubes stacked next to each other? I have not done any calculations yet to get an approximate size (it is late at night), so that could be the answer.
RE: Heater for LPG Liquid
You can see that I am trying to minimise the trouble I expect to see with a heater against sea water.
