dwf to dwg convert
dwf to dwg convert
dwf to dwg convert
Can anyone offer a decent way to convert DWF files to DWG files.  I have a large project where we can't get DWG backgrounds, only DWF files.  Since these were obviously created with AutoCAD, I am hoping there is an easy conversion tool.
Thanks!
RE: dwf to dwg convert
That is kind of the point of the dwf file now isn't it.
Although I have never worked with them, I do believe that you overlay them into your drawings.
I would think the only tool out there would be a crack and not sponsered by autodesk.
Zuccus
I have found various freeware and shareware programs online to use.  I was hoping some one would know of something that would be appropriate.  I don't do much work in AutoCAD.  My work is done in AutoSprink, which is a 3d fire sprinkler program.  But, AutoSprink will import DWG files.  The problem is that I need to convert the DWFs to DWG before I can import to my program.  I know that ACAD 2008 will allow you to reference the file, but if I can't bind it, it doesn't help.  So, I am running out of ideas.
Thanks for your help and suggestions.
TurboCad will read about anything and output about anything you can think of...
Try the online free version or pick up an older version on e-bay for cheap.
www.turbocad.com
I have just had an experience with a similar issue.  I use AutoCAD Civil 3D and received a DWF to insert.  All of the converters that I have found will convert the DWF to a DWG with a catch.  The DWF becomes an image in the DWG file that is created.  I don't know if that is of any assistance, but there is no dircet conversion of a DWF to a vectorized DWG.
