Hole Wizard Callouts
Is there a way of calling out the type of fastener with hole callout ie "Hex Bolt" I know you can callout things like <hw-cbdepth> to get the counter bore depth, so I was hoping there was a way of calling fastener type I'm just not sure what it is.
RE: Hole Wizard Callouts
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
That's true, but I would like to have custom hole types that would contain information specific to certain fasters...mainly with PEM's. I spend a lot of time typing out "FOR FHS-0420-8"...it would be nice if custom databases were easy to set up (maybe they already are).
I found this Variable "<hw-fsttyp>" - which means Fastener type. If you had Toolbox and you used a Hex Bolt, then you can add this variable into the callouts and it will give the Fastener type.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
Ken
