Socket or a Butt weld on an API 10,000 psi flange
What kind of weld would be a better option, a butt weld or a socket weld on an 1 13/16" -10,000 psi API flange (super duplex UNS S32750) to a 1" ID tube, 0.118" tk strangely thin!!!(super duplex UNS S32750) which is also rated to 10,000 psi. The assembly has to be rated to 10,000 psi
Thank you for the time
RE: Socket or a Butt weld on an API 10,000 psi flange
