Steel roller availability
The company I work for has a product that uses steel rollers which are hardened and chromed. The specifications called out for this roller are way overkill for our use (60 Rc, dia tolerance of .0005", etc) and the small quantity we use makes them costly to produce.
What I'm wondering is:
Where I used to work we made a steel roller mill once that formed strips of steel into various shapes using many sets of rollers. There must be companies that manufacture these roller mills on a production line-type basis, and therefore have replacement rollers as stock items, especially the flat ones I need. I can easily modify our design to fit a different roller, I just need a source.
These rollers are about 2 3/4" long and 3" diameter. If anyone has an idea as to where I could procure such items, I'd appreciate the input. I've done some searching myself but have had no luck thus far.
Thanks!
Thanks!
RE: Steel roller availability
Russell Giuliano
supplier. They make these for cross roller
bearing assemblies. The length would be
less than 70mm and probably 65mm long.
You might call Rotek Inc. and see if they
have any extra rollers in stock that they
would be willing to sell to you. They are
located in Aurora Ohio. How many do you need
and how many per year? They should be able
to tell you who they buy these from too.
timeline1968
Here is a partial listing of companies that manufacture rolling mills on a production line basis. you can Google these to get their addresses :-Oliver, Engel, Flagler, Lockformer, Yoder, Tishken.
There are others.
B.E.
dimjim: Rotek doesn't appear to have what I'm looking for either, but thanks anyway.
berkshire: These are the types of companies I was looking for the names of. Hopefully one of them can come up with something. Thank you.
