Hmm.. well to start, you sound pretty new to the industry, so I'll help you out. I was a batch plant operator in Florida for a year at a DOT, ACI, PCI, and CMEC approved facility. If you are inspecting a concrete batchplant, the W/C ratio relates to the desired strength of the concrete, with class V and VI concrete having 6500psi and 8500psi, respectively. They required no higher than .35 and .32 W/C ratios. Consider all cementicious material(flyash, slag, silica fume or slurry) for W/C ratio. When Inspectng a batchplant, verify that all materials originate from the labeled source, check records for inventory receipts, and keep an eye out for anything funny. Check for recent scale calibrations, a treated water source, and depending on state, BP operator certification. Make sure that batch weights are batched within tolerances, often not varying more than 1-3%. Material reciepts in records for items not on an approved mix design can indicate something fishy. A high range water reducer is the same as a superplasticizer, both dramatically reducing the amount of water needed for a high slump, but this comes at a price. The lack of free water can accelerate set times, so a retarder is usually used in conjunction. Flyash is often called a filler, but has cementicious properties. Its fine particles act somewhat as a densifier, reducing permeability on a coulomb test and reducing costs as well(it's cheaper than cement). As far as plasticizers are concerned, look at the manufacturer's labeling on tanks or dispensers, they are often clearly marked as one class or the other, for there are all three types of plasticizers(and sometimes there is more than one type on the same product, like cement can be). You may want to review a few working mix designs from that plant before inspection, just to give you a heads up. Understanding Specific Gravity for items is crucial for uderstanding yield(both theoretical and actual).
I like to talk concrete, as you can see, and I'm ACI field and lab tech certified, as well as PCI level I and II, and various Florida DOT certs(including batch plant operator).
