power circuit calculations
hii.. im new in the field of power electronics.. currently im an engineering trainee with TYCO electronics.i hv done my engineering in electrical and electronics
i need sum help in knowing how to make the power circuit and control circuit drawings for a switch board design.
i want to know how to go about with these drawings n material which i should go through.
RE: power circuit calculations
Is your question referring to software or construction materials and specs?
If it is broken, fix it. If it isn't broken, I'll soon fix that.
i hv ppl here to help me with the basic calculations but i was looking for some literature references for the subject dealing with the calculations n explaining its significance...
if u hv some software pertaining to the subject... or some online links in any format it would be very helpful...
thanx
htt
I don't have an attitude problem. You have a perception problem...
For the draftings like TurbineGen said check in your company for older draftings. That is from what I started, now they are working with my drafting as a roll model for newbies. The way how technical drafting should look like are usually defined in national standards, At least that is the case here in Russia (I work for Austrian company, but I need to honor Russian drafting specification on that matter).
My advice to you, If you draft so that electrical salesman can recognize equipment on your drafting you did a good job :)
My main concern was to get the informaion which i was looking for, which i have got thanks to ssolobodan, ScottyUK and TurbineGen.
As far as using the aforementioned language is concerned, i wasn't aware that you couln't use it in a public forum like this site.
Thanks a ton for informing me.
Rashi
Furthermore we are talking about subjects that need as much clarity as possible for answers to be understood and comprehended. These details can be clouded or lost while readers are focused on decrypting the strange text.
That's why we want as clear questions as we can get.
Thanks.
Keith Cress
sms tp txt sn't fn 2 rd & ttly /necessary
Gunnar Englund
www.gke.org
Keith Cress
