CNC Foam Model Capabilites in Vancouver BC area.
Hi All,
I'm looking for a CNC machine capable of making a 14' boat model out of High Density Foam.
Anybody know of any manufacturers or shops that could handle this job?
60% of the time, it works every time.
RE: CNC Foam Model Capabilites in Vancouver BC area.
www.axyz.com
B.E.
www.vancouverwireedm.com
Last time I had to make a sizeable foam model (about 200 cm x 50 cm), I modelled it in sections, complete with matching dowel pin holes for each section. Once joined, glued, filled, and painted, it looked fine.
Thanks for the links!
Based on that, composite pros suggestion of www.janicki.com. sounds like your best bet, they can do your model in one piece. whenever you get it sent to you.
B.E.
cut 100'long parts and are familiar with foam machining.
h
Good luck,
