How to delete views in ".idw"
I want to delete the base view and cross-section view and just keep the projected view in a ".idw" Inventor drawing... But when I right-click either the base or cross-section view and click "delete", all views go away... How can I keep the projected view and delete the other 2 views??
RE: How to delete views in ".idw"
Powerhound
Production Supervisor
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Select the view you want to delete. It will ask you if you want to delete the other views. There is a "double carrot" symbol in the delete dialog box, this will expand the dialog box. Just click where it says "yes" for the views you do NOT want to delete and it will change them to "no".
David
In the same dialog box there will be a square button with the double carrot symbol (>>) in it. Select this and the dialog box will expand to show the dependent views and whether or not they are set to delete.
p://w
David
[IMG]http://i13.tinypic.com/6g2eujk.jpg[/IMG]
David
I am using Inventor Professional 11, SP3...
Again this is a direct screen shot of Inventor 11 SP3.
ht
David
